Revolution 52 & Cooling Fan/Shroud
My Feedback: (10)
I am interested in putting this engine in a TF Giant P51 using the Cooling Fan & Shroud set up designed for this Engine/Plane combination; is anyone else using this combination, and if so, how has it been working out.
Thanks, Doug.
Thanks, Doug.
My Feedback: (10)
RE: Revolution 52 & Cooling Fan/Shroud
David;
From some pictures I saw of the shroud mounted inside the cowl, any problems getting the cowl on without having the fan blades rub on the inside of the shroud; also, what make and size prop have you found works for you with this plane and engine.
Thanks. Doug.
Thanks. Doug.
