Baffling this engine Need HELP
Old 08-30-2007 | 09:20 PM
platero's Avatar
Default RE: Baffling this engine Need HELP
hi pe reivers i can see your side mount of your engine, have you problems later to balance the model laterally??
Old 08-31-2007 | 09:13 AM
Platero,
I do not fly Imac or any other fancy aerobatics. A bit of side weight counteracts the engine torque, so is no problem at all.
If I were to change my flight patterns, I probably would mount my engines inverted.
Old 08-31-2007 | 11:50 AM
platero's Avatar
pe reivers
Thanks for your answer, y supposed some thing like this in other way some weight mus to be added in the opossed wing.
Old 08-31-2007 | 03:52 PM
If you pull a loop, and one wing comes out low, that is the sighn to add weight to the other wing.
