Engine Cleaning?
Old 03-16-2003 | 06:45 AM
Default Engine Cleaning?
WHAT EXACTLY DO YOU HAVE TO DO WHEN YOU CLEAN A ENGINE IN ANTIFREEZE?DO YOU HAVE TO REMOVE THE CARBURATOR AND GLOW PLUG? DOES IT MESS UP THE DIAPHRAMS IF YOU DON`T REMOVE THE CARB? HOW LONG DO YOU LEAVE IT IN THE CROCKPOT? THANKS
Old 03-17-2003 | 02:20 AM
I use the antifreeze quite often. I do not use it for carbs. I spray them off with the aerosol carb cleaner then dissassemble them and spray ther inner workings. I am not sure what the antifreeze will do to gaskets or seals, I always dissassemble my engines removing any seals and gaskets before putting in the pot for 12 hours. Use straight antifreeze, Do not cut it with water and the parts will come out clean.
Old 03-17-2003 | 10:36 PM
Default Crock ;-)
...and be sure you never use that crockpot for food again.
Old 03-18-2003 | 02:45 AM
My Feedback: (16)
Disassemble it as much as possible and remove all the gasket material that you can. Cook it overnight and then clean it off with solvent or water and WD-40.
Old 03-18-2003 | 06:05 AM
w8ye's Avatar
My Feedback: (16)
Don't boil it. You just want it to be hot. A potpourri pot works better if you can find a old one.
Good luck,
Jim
Old 03-18-2003 | 10:36 PM
Yakdude's Avatar
Hello,
I use the crock pot method also. Make sure you use a low setting or the aluminum will dull. I usually leave the parts in over night.
Lenny
Old 03-19-2003 | 07:15 PM
My Feedback: (16)
Definately make sure that you don't overheat the mixture. Just make sure that the pot is on low.
