*Brillelli 26-SSR*
#351
RE: *Brillelli 26-SSR*
Check also if you have no air leaks between carb and intake.... Since you mentioned changing the needles didn't have such a considerable effect, I figure you must be having an air leak..... Get some high temp sealanta and place it when you mount the carb to the intake, but don't let that cover up your pulse line.... Another idea, make it a little more rich and get a larger prop (17x10)....
#352
KY
xtraflyr, yeah my concern is sitting in the pits and taxi to the flight line. Safety is my biggest concern. I have an opti kill switch. My two safety officers in the club are DA and Zenoah fans, with no idle issues on their planes, so I don't have much wriggle room.
I never thought about running a low pitch prop to help reduce the pull at the low end. Reducing thrust is usually not the objective. I will give that a try. Thanks.
cosmospho, I have run a 18X6 and a 16X8 that did not make much difference, except on the high end. Scott also suggested I look for leaks around the carb. I did not pulled the neoprene adapter off the head when I swapped the carbs. It looked tight to me, but I will check it again. When I pull it again, I will scan the whole block and cylinder too.
#356
I have been waiting three months for a 46GT. Scott eventually replies to e-mails but lately even that has stopped. We all go through times like this and I am trying to be patient (no choice really). Frankly I think he should have just suspended service for a couple of months to get himself sorted out and get caught up on the backlog and not spoil a well earned reputation; I for one would have totally understood. Let's hope things get sorted out soon.
#359
CA
I had called Scott three weeks ago. I asked him about ordering the 46GT. He told me that it would be about 3 - 4 weeks. I have been trying to get an up date on my engine. I have called lots of times and I have sent e-mails. Today I sent a letter asking for an up date. I know he has been sick. I hope he is OK !! He could be gone on a vacation, with it being the 4th of July week.
#360
KY
Couple of things:
First of all I want to thank xtraflyr, and cosmospho for the advice on my IDLE problem. I did find where the cylinder/block gasket seem to be pushed out under the carb. I loosened up the block bolts shoved it back in and put some high temp sealant on the spot. I'm not sure if it was leaking or not. But I just tested the engine, fire right up and settled down to 1,650. Success!
Secondly the leak advice matched what Scott had emailed me and told me over the phone as well. Guess I should have paid more attention. But the nice thing was Scott's email yesterday offering to take it back and fix it for me. And yes that's what I said the email was yesterday evening.
I too have had major delays, and at time wished I had ordered another engine. But I'm glad I have these two, B46 and 26SSR. The performance rocks. Such is the price of success. I have worked with Scott for two years on my engines, and I agree he is a stand up guy.
My advice to those without one is order early and have something else to fly, or order something for more money or less performance.
#361
NJ
ORIGINAL: ledsled
Couple of things:
Couple of things:
Scott has always tried to help me out by taking a motor back,if I wasnt happy. I too have a 46gt and the 26ssr.My dad has the 26ssr in his 80"span World Models Zero. My friend also has a 46gt and his dad has the 50cc. Were all very happy with our purchase.. I would buy from Scott again for sure.
He may be backed up due to family/health problems,but if you want he can have the motors made in China and they'll be garbage,but youll get your motor quicker..
Cya,
Frank
#363
Xtraflyr your dad has one in a 80" Zero!! Do you know what weight that plane is. I ask because i ordered this engine about a month ago for my 100x and have since came across a great deal on a 120 surpass. I still want the engine, just would like to know what is the upper limit of weight that this little engine will 3D?? Also i have heard from some guys at the field that since this engine is such high reeving it must lose some midrange?? how does yours preform there?
#364
NJ
ORIGINAL: skillet92
Yup as do I in a 73"KMP Hawker Typhoon that weighs just at 18lbs.It flys both if them beautifully.Im not sure of the weight of my dads plane but it has to be in the 15lbs range or more. Most of the time when we maidened dads Zero,it was in the midrange.Both of our engines are very new only one flight each on them. My Typhoon lowend was on the rich side so it was quite burbally(SP). Basically this engine will fly anything that uses a OS 160 2stroke.I would imagine it would fly your 100X no problem.
I believe Jake Ruddy(Sinergy) is going to put one in the new 78"Extreme Flight Extra and run it on a Tuned Pipe. I also remember hearing guys are running this motor on the Ultra RC Giles/Katana. Again both that are ranged for the OS 160.
Cya,
Frank
#365
ORIGINAL: skillet92
#366
My Feedback: (97)
OH
Mine, on a ESComposite Pipe and Mej 18x6, would easily hover my 13-lb'er It would also pull out of hover very well. I will have this plane back in the air soon and will get some video. Midrange was a little sharp in that it required some throttle curve to get a little more resolution. I was getting used to it for hovering and 3D before I nearly destroyed the plane.
David.
David.
#367
ORIGINAL: plasticman
David.
David.
#368
CA
Hi guys
Got a nice email from Scott. Looks like he has the parts he needs in stock finally and is clearing his backlog. Hope he can find it in his heart to rejoin this thread after being dumped on in the past. Maybe the moderator can convince him. He has the answers to most of our questions.
#369
CA
http://www.rcuniverse.com/forum/m_76...mpage_2/tm.htm
Post 35
And then check out post 45. That should say it all.
Post 35
#371
Hank,,,I believe the 26 is going to be great. I am worried that it will ever be shipped, but just got an email from scott saying the problem was the new head gaskets and his solution is a copper gasket that results in less vibration and more power. He is shipping my order on Monday. That's two days from now. WOO HOO!!!
#372
My Feedback: (77)
CA
Hello,
I was wondering what is the best way to start the 26 ssr?
any different way when engine hot? mine is difficult for me to start, some times worst than others. Also I'd like to know opening( NO. of turns) on your high/low needles.
ORIGINAL: shawn45
Hello,
Hello,
Choke on, Ignition on - Flip until it pops (usually 5 flips)
Choke off, Ignition on - Flip until it starts (usually 1 or 2 flips)
If the engine is warm no choking is required.
Both of my needles are about 1 1/4 out.
If your motor is too rich, it will be more difficult to start.
#374
KY
After all the trouble with the idle out of the way, I took my Sukhoi 31 with the 26ssr out yesterday for the maiden flight. It ran well, even with the heat and humidity. I took off and flew about 8 laps in the pattern with plenty of power. Tested the vertical but not too much being a maiden flight. I started to make a couple approaches, I went to about 1/3 throttle and she died. I dead sticked in with no problems.
I found the gasket problem had returned, but a bit worse. Must be some really high pressure. I guess I need a new gasket, maybe something stronger. I saw something in a thread in RC universe that there is a stronger one?
#375
My Feedback: (40)
hrmm well there are 2 suggestions.. you have either use that copper permex (can't remember the name off the top of my head) or there is a red anobolic lock tite gasket maker that is available at places like NAPA. Either should keep that gasket staying in place. Both require 24hrs to dry but should fix her right up no problem.
