25 cc US Engine
My Feedback: (21)
MN
I have a 25 cc gas engine that i installed in a 120 lite the engine has electronic ignition the carb has 2 needle vales, high and low setting my question is how many turns on each needle is required to get it to start.
My Feedback: (49)
AZ
Turn each needle out 1-1/2 turns to start and then lean both from there.remember when you lean one you need to adjust the other.most of my engines seem to like 1-1/4 turns out for low,1 turn out for high.But it also depends on your elevation and climate.
