Smoke System Your Thoughts
Old 02-26-2002 | 09:35 AM
Default Smoke System Your Thoughts
Hi guys, which is the best pump (electric or vibration) to use in a smoke system? Are you having success with yours, if so, which smoke fuel do you use? I can't buy smoke fuel where I live, so I will have to make it, please give me your recipe.
PS; using a 160FX with a slim line pitts style smoke muffler
Old 03-10-2002 | 03:53 AM
My Feedback: (9)
I use TME's Simple Smoke Pump...they also have fuel recipe's on there site...http://home.att.net/~tmenet/index2.htm
Old 03-10-2002 | 03:33 PM
mikerc's Avatar
I had an Edge 540 with a Fox 2.4 gasser running a TME smoke system. It worked great. Check it out on my site.
http://www.ros********.com/edge_flyi...ures/index.htm
Old 03-11-2002 | 05:35 PM
I also use the TME-love it-however I have heard great things about the B&B if you ever run gas.
Old 03-12-2002 | 08:21 AM
Sounds like the TME is the one to get so i will order one soon. THANKS for the feed back guys
Old 03-25-2002 | 01:37 PM
My Feedback: (8)
Default Smoke
The TME system is good the one thing you try to do is to get the smoke oil as hot as you can get it. A good preheater in the muffler helps alot. Super Dri smoke oil is the best.
Cheers
