Zenoah Engine Question
Obtained a converted Zenoah engine and I don't know what I have.
On upper cylinder it says Zenoah 1650 this is followed by a circle with the numbers 1 thru 9 and the letters xyz around the outer edge.
In the middle of the circle there is the number 97.
Can anyone identify this engine?
Interested in knowing anything such as what it was originally used for as well as the size/power of the motor.
Thanks for the help.
CASSIDY
CASSIDY
Thanks RCIGN1 for your help. The carb is a Walbro and the marking is WT3.
I don't know if it is the original carb. You mentioned doing a cross referance.
Is that something I can do? If yes, how would I proceed?
Thanks again for your help.
Paul Ryan
PS I think that this section of RC Universe is the best thing on the net, great people and great information. Playing (working) with these small engines is a hobby unto itself!
Paul Ryan
cassidy: Try the website www.walbro.com it should bring up a engine brand selection...then ckick on the brand you want data for. You will be able to match no on your carb...to what power tool this carb was on. Good going....Captinjohn
Carb must not be original as I could not find a match.
The motor also has another number 4FGJ134. This is preceded by a diamond box that has KDC inside.
Any other way I can trace this?Any help would be apreciated.
Paul
Paul
