3W 150 Cooling Question
Old 10-11-2007 | 01:08 PM
OldScaleGuy's Avatar
Default 3W 150 Cooling Question
This is my first experience with a twin cylinder gasoline motor. My question is will the set up the way I have provide proper cooling? This is not an aerobatic plane, it is for simple straight flight with mild aerobatics.
ID:	781040   Click image for larger version
ID:	781041   Click image for larger version
Old 10-11-2007 | 05:30 PM
Default RE: 3W 150 Cooling Question
If you ad a baffle in the lower cowl half to close air bypass off, you will have an excellent cooling system.
Old 10-12-2007 | 08:09 AM
OldScaleGuy,
Pay special attention to proper baffling of the cowl, or you could end up like me, seizing up your new Twin. Now I have baffles build from 1/16 balsa and then glassed over for strength. Those baffles force the air flow directly over the fins and then down out the bottom exit. Make sure the air after going around the fins will be directed out without being disturbed. In my case I had a good air intake but my exit was somewhat blocked and the cooling air was trapped, causing overheating. A good insurance to prevent seizure is for the first time to fly for only five minutes maximum, land and check the temperature with a infra red gauge thru the front intakes. Any reading over 250° F should be considered hot.
