mvvs 1.6 redhead
My Feedback: (109)
I am trying to adjust the midrange on this MVVS 1.6 gas engine (redhead)-it seems to be four stroking at 1/2 throttle, it has a great idle, great top end (swinging a 18X8 @ 7200 rpm) pulling a 80 inch GP chipmunk-what do you think I need to do-thanks in advance-I found the mvvs engine being discussed but got tired after reading 10 pages and not finding what I need-
CA
My MVVS 1.60 gasser also "four strokes" at half throttle with good idle and the top end mix set at best power. If I lean the idle mixture to clear up the midrange then it is too lean to accelerate from idle. I just have just had to live with it. I have it in an 80 inch Hangar 9 P 51 which needs every bit of power the MVVS will deliver...so I just fly around full bore.
Jerry
Jerry
The rich midrange probably is muffler related. With a MVVS tuned pipe it sets in below 1/3rd throttle.
If you like to try, you can close the third idle jet in the carb (closest to the carb mouth) to improve the situation. If you goof, a new carb is due.
hi i have the mvvs 1.6 redhead to and the ICU-L ignition .Is a 5cell 2000mah nimh pack ok? and how the spark wire securew on the plug it jast stays pluged?do i need to wrap[ the ignitin with foam? it has its own silentbloks.....
ORIGINAL: aandreas
My Feedback: (10)
TX
My needle settings do not hold. Seems like I have to tweak them a bit each time out. Admittedly, I don't take it out but once a month. On factory pipe, the engine runs super and sounds like a souped up 0.61 glow.
