BME G90 - Spark plug
Hi, Any one got an idea where I can get spare SPARK plugs for the BME G90 gasoline engine.
Thanks in advance for your replies.
Giri, INDIA
Giri, INDIA
CA
If it's a NGK-CM6 get em here ------->http://www.aircraftinternational.com/
Well, it doesn't have a number on it. But it's not the NGK CM6. It's quite small and fits where an OS#8 plug would normally (on a glow engine). I am going to try and post a picture of it.
Thanks for replying.
WY
Given your location, you should check for an NGK ME-8 its also a 1/4x32 spark plug.
Depending on your spark plug life and time to get a new one, think about modifying/making a new head for use with the 10mm CM-6. It is much less and last much longer. You would also have to change the spark plug cap.
I spoke to CH Ignitions and placed an order for Rimfire 1/4 x 32. The airmail charges are the same for 1 or more plugs, so I went for 4 plugs. Based on my flying it should last me a while. But these plugs are fragile, the manufacturer (Mr. Keith Baker, BME) cautioned me a few times. I'll check with him on the mods to 10mm.
Thanks for your help and suggestions.
