E3 Diamond Fire spark plug
My Feedback: (12)
GA
O.K. I did a search and didn't find anything on these spark plugs. Has anyone heard of or used the E3 Diamond Fire spark plug? I am getting ready to put them in my Zenoah GT-80. It is a direct replacement for the Champion RCJ7Y. They are guaranteed not to foul for life. I got them at the auto parts store. The choice was these or autolights.
Shan
Shan
NC
I bought one of these plugs, ran it on the ground and it did fine. Then I realized it didn't have an "R" in the name and I became concerned about RF interference so never flew it.
That would be my only concern and for all I know, it may be a resistor plug...just didn't indicate it anyplace I found.
If you have a multimeter you can check for resistance in your plugs by placing the leads on the center electrode and the terminal on top. If it is non-resister it will read very close to 0 ohms. I checked several small engine resister plugs and they are showing about 22k to 24k ohms. One was a brand new Champion RJL19LM still in the box. I checked one non-resister I had for my old race car and it showed less than 1 ohm. If I had sanded the coating off the terminal end it would probably have been 0. If the E3's show high resistance like this I wouldn't hesitate to use it.
My Feedback: (12)
GA
I finaly got a chance to fly and there was no problem with interference. I range checked and then flew. The engine ran better than it ever has. I was very pleased. The only problem is the plugs are about .25 inch too long. The cowling fits real tight and the spinner does not line up straight.
My Feedback: (19)
ORIGINAL: shann
