Bme 50
Old 04-06-2003 | 11:27 PM
Default Bme 50
just purchased a bme 50 from Dons Hobby shop on friday and installed it on an DP Edge 540 T. I went to the field today and was not able to fly Because kept gettint glitch with motor running I moved everything around could not get to stop. A friend come up and said to move my ground from mount on bottom of motor to carb. Moved it there and now engine will not even start no matter where I move it now.
Old 04-06-2003 | 11:58 PM
My Feedback: (14)
Default Bme 50
Check your hall effect switch. you probably shorted it out by trying to run the engine with the ground on the carb. Most carbs are insulated from the cylinder by a composite material to stop the heat transfer. Attaching the ground there would be like completely disconnecting the ground. Then the spark would be forced to return from the engine case through the ignition pickup sensor. That has happened to me on an engine that I had a couple of years ago. I failed to connect the ground wire and blew the switch on the first start attempt.
Mark
Old 04-07-2003 | 12:13 AM
Default Bme 50
Thanks Mlevings!!
what is the hall effect switch and how do I fix it. Iam new to gassers.
Thanks again
Old 04-07-2003 | 12:39 AM
My Feedback: (40)
Default Bme 50
The HALL SENSOR (it goes by many names) is the sensor near the prop hub. It is a magnetically triggered switch. The magnet is IN the back of the prop hub. If you have no ground and try to run the engine, it is possible to damage the ignition module. The best thing you could do now is to mount the grounding strap on the plug ( I use a hose clamp and clamp it to the HEX part of the plug) and try to run it, see if it fires. leave the plug out of the engine and crank it over with the ignition on, check for spark. If it fires, put the plug in and run it with the ground strap hooked up like this, see how it runs.
Old 04-07-2003 | 12:42 AM
My Feedback: (40)
Default Bme 50
BTW,
WELCOME to RCUniverse
Old 04-07-2003 | 01:20 AM
Default Bme 50
Well I guess something is fryed cause it wont spark. I wonder how I can fix it.
Old 04-07-2003 | 01:24 AM
My Feedback: (40)
Default Bme 50
Make the call to BME (Keith) talk to him. He will most likely have you get in touch with C & H Ignition.
Old 04-09-2003 | 02:38 AM
Default Bme 50
Well Received my new hall switch today and works perfect also used clamp on plug for ground and no more glitch. Man what an awesome flying machine.
Thanks every one for the advice
Old 04-19-2003 | 12:25 AM
Default Bme 50
Concreethead, I just got the new DP Edge 540 T last week. I too am new to gassers. I using a DA 50 in mine. How do you like the plane and what does it weigh with the BME 50? I'm figuring it to be around 14 lbs, hopefully less, but I'm interested to talk to someone who already has one. Thanks
Old 04-19-2003 | 02:17 AM
Default Bme 50
Hey Kelly D
Welcome to RCU, check out some threads in the ARF area under the airplane section. Here is one to get you started. Where do you fly at? http://www.rcuniverse.com/showthread...382&forumid=57
Old 04-19-2003 | 04:15 AM
Default Bme 50
I fly in sylmar, how about you?
Old 04-19-2003 | 01:22 PM
Default Bosch Cap
Has anyone tryed the Bosch cap on the BME50? I have one and have thought about using the cap instead of what I am doing now. I now have the braided wire soldered to a round terminal then a bolt that goes throught one of the holes in the cooling fins in the head. I have lock washers on bith sides of the fin
