G20Ei is the best!!
#401
RE: G20Ei is the best!!
Up front let me state that I do not have first hand experience with this engine but it sounds to me that you are trying to get too much out of the engine too soon. In other words, by reading your post you say the engine started to sag. Were you at WOT (wide open throttle)? If so for how long? I would follow Karol's advice a few posts back as far as adjusting the high end needle to peak RPM then stop. Adjust low RPM to where you have a smooth transition from low to high then fly the airplane and adjust as required after flying. I am not a fan of prolonged running on the ground.
I hope you get it worked out.
Glenn
Glenn
#402
A new engine should not be run at WOT for any extended period of time but rather at a mid throttle setting for a few minutes then shut down and allowed to cool for proper heat cycling to take place. As Glenn suggested breaking-in an engine is best done in the air where it can get adequate cooling, just refrain from any full bore verticals and prolonged high speed runs. Tune the engine as suggested earlier and fly the model, then do any tuning adjustments that might be necessary. Also don't try for too low an idle before the engine is fully broken-in. The G20 is a great little engine and if treated properly will possibly outlast you.
Karol
Karol
#403
ORIGINAL: willig10
Glenn
Glenn
I had set the high end by going to highest rpm and them riching up the needle....low end for best idle and accleration
#405
ORIGINAL: karolh
Are you sure that the ignition batteries were fully charged as low battery power can give the symptoms you described.
Karol
Karol
I dug out a couple of my old recip books from my days of working on General Aviation aircraft....as I stated in original post I replaced the stock ignition with one from CH....the stock pickup is a fixed assy however the CH pickup is adjustable....so I am thinking that I may have mis-adjusted the firing timing....a to far advanced timing could cause the engine to run hotter than normal.....which could cause the spark plug to get hot and act like a glow plug....which could explain why the engine continued to run after I shut off the ignition.....
I haven,t had a chance to recheck yet....other priorities maybe on Saturday....
Does that sound like a reasonable explanation to you?
Thanks for your reply
#406
Having a gas engine continue to run after the ignition has been turned off indicates some big time pre-ignition, which is very unhealthy for the engine. Do a re-check of the timing bfore you attempt to run it again.
Karol
Karol
#407
ORIGINAL: karolh
Karol
Karol
#409
ORIGINAL: AA5BY
Please define continued to run after turning off ignition... did it run well or ran sputtering?
It was not sputtering but running at reduced rpm....It also sounded as tho it was laboring....
#410
A possible explanation though probably only remotely possible is that an error was made when connecting up the switch harness. If the switch harness were looped inadvertently and the battery connected direct to the ignition and the battery ran low, it would explain a lot. A G-20 will go to low throttle and not rev but remain running when the battery gets low. Of course if that is what happened, turning off the switch would have no effect.
Gasoline engines when running on other than the spark plug usually detonate because of overheating or carbon deposits glowing but when they do, they fire too early or late and without consistent timing to run smooth at any rpm.
#411
ORIGINAL: AA5BY
#413
The explanation will be interesting. I was just wondering what the result of wrongfully filling a gasser with nitro glow fuel would be. Would it run but overheat and continue to run without ignition in a grossly overheated condition?
The only other thing that comes to my mind is if the switch were faulty and not opening or a capacitor were introduced in an attempt to bypass ignition noise. The wrongful use of a polarized cap would energize the ignition for a short period after the switch was opened. This might not be noticeable with the energy hungry stock ignition that would drain the cap quickly but if the ignition were changed to an RCXl unit, ignition might be provided for a short period after the switch were turned off depending of course on the value of the cap.
My apology for raising the bazarr possibilities but this is an unusual scenario.
#414
ORIGINAL: Antique
A gasser won't run with the ignition disconnected unless it's melting down inside, in which case it's no longer usable...
I went to field today ....gassed up the airplane....checked the voltages on all the batteries.....went to full choke, turned on the ignition, third flip engine popped, opened choke , third flip and engine was running....
let it warm up at idle for several seconds....accelerated to full.... engine never missed a beat sooooooooooooo I figured hey why not! I taxied to runway and took off....airplane went down the runway and took off just like it was supposed to.
Ten minutes later landed, engine never missed a beat....what a great little engine...!!!
Gee! all I did was recheck the timing guess what it was close to 35 deg!.
The CH pickup mounting bracket has slots where the mounting screws attach to the engine...evidently when I set the timing the first time it must have moved when I tightened the screws down and me the big dummy didn't recheck it.
set the timing to 28 deg this time and it starts and runs perfect....
betca those cheapy other engines would have been totaled with that abuse....
Thanks to all
I hereby confirm that I will always double check my work henceforth
#415
Make sure you continue sleeping on the side you did the night before you switched ignitions are you are one lucky so and so. Glad it seems to have turned out okay but just to be on the safe side it might be a good idea to have someone experienced in small gassers pull the jug and take a look see.
Karol
Karol
#416
Yup I think so also....I will keep a close eye on it......back in the day I replaced jugs on R 2800 engines when I worked Dc[6 aircraft....I think I can pull the jug on that little 20cc...
ORIGINAL: Hircflyer
Karol
#418
ORIGINAL: karolh
How is the G20 behaving, hopefully all is well with it.
Karol
ORIGINAL: Hircflyer
Karol
#419
Well after several gallons of 90 octane pump gas with Red Line at 40:1 my G20 timed at 28 deg. on an RC exl ignition is no closer to attaining the magical figure of 9,000 rpm spinning a Xoar 16x6 prop so many folks talk about. Not even the use of an after market side dump muffler at my club's field at sea level which gave a significant increase, much less at my home field at 3,000' has it ever happened. Only the use of a mousse can muffler and header pipe combo did it attain and exceed 9,000 rpm. I'm not complaining as the engine gives more than enough power for the models I fly and the 8,400 rpm it gives on a SPE 26 lightwweight side dump muffler is more than enough for me.
Karol
Karol
#420
My Feedback: (79)
Karolh,
Try a Piston ring from Frank Bowman like I just installed. I am also running the same ignition and timing setup as you are. I just modded the stock muffler by removing the stock baffle/pipe, and brazing in a 3/4 piece of thin wall tubing. The difference between his ring and the Stock ring is night and day. After 3/4 of a gallon of 91 octane/32:1 Penzoil Air cooled, I am getting 9,400 steady with a APC 16-6, and have seen as high as 9,480 flash on the Glow BEE tach. I will try to snap some pictures today. The compression is noticably better, than the perfectly fine stock ring, and actually felt stronger before I even ran it in comparison. The engine has a noticable thump when you turn it over now. I am sold after this last mods, and cannot believe that I waited that long to do it.
http://www.rcuniverse.com/forum/m_91...tm.htm#9107979
#421
Very interesting results on the change of the ring. karol, as no doubt you know but I'll remind, all props are not created equal. Recently I compared two 16x6 props on a G-23. The wood Zinger produced 8300 and the APC 9200 with an occasional sighting of 9300. That is a 1k difference in rpm though who knows what if any thrust difference as I've not flown both props yet. Both of my G-20s run about 8900 on an APC 16x6.
#422
Iflyglow,
My engine runs great with loads of compression so I'm not too sure that changing to a Bowman ring would make that much of a difference. What increase in rpm did you notice with just the ring change in your engine.
AA5BY,
You are so very right that all props are not created equal, as it was when I made the transition from glow to gas was when I realised the vast difference there can be in the performance of props of similar specs. On my G23 a Xoar 16x8 spins at 8,300 at my 3,000' elevation and though 300 rpm less than a similar size APC, outperforms it in flight. My G20 spins a Xoar 16x6 at 8,400 and while this figure might be down on what others achieve, my engines run very well and give more than satisfactory flight performance to my models.
It would be interesting to see how your model performs on diffent brands but similar sized props, so please keep us posted on that.
Karol
AA5BY,
Karol
#423
1 Post
ORIGINAL: AA5BY
What about a larger prop, even an 18x6, how does this engine handle those?
Does it have enough torque to drive those props properly?
#425
1 Post
Thanks Ralph,
I had a suspicion they would work fine! I just bought one of those engines for a H9 Taylorcraft and didn't like the prospect of glow-engine type prop speeds.
I might try an 18x6 Biela that I have floating around somewhere
