Please help ID this gasser
It is a remington for sure. I have the exact one. Those engines were out of the older remington mighty might saws from the early 80's.
The Letter E on the head is not really the letter E. It is a casting that gets machined down , then it looks like a E. The 2 outside lines of the E originally extend upwards, so it looks like a E on the bottom then changes into a U.
It runs good, i had a 20x6 prop on mine and it flew a 20lb plane scale like.
The connecting rod, rod bearings, bore are like a quadra but the crankcase is a different design. Also the crankshaft bearings are different .
