Fuji gasoline kill switch
Old 01-24-2008 | 07:59 PM
2robinhood's Avatar
Default Fuji gasoline kill switch
What are you guys that have Fuji gasoline engines useing for electronic kill switches?
I have Five gasoline engines.
I use the 42-percent-products opto kill switch with great succsess except on the Fujis.
DL-50, Brillelli 36GT, and CRRC Pro GF26I they work perfect.
On the two Fuji BT43EI-2's the engines break up at all rpm's
The faster the rpm the faster the break up / miss is.
I have been trying different things with 42-percent-products but nothing is working.
They believe that the Fuji's ignition is throwing lots of RF out.
I was thinking of trying the Smart-Fly kill.
So, Fuji guys, what are you using.
Old 02-14-2008 | 07:23 AM
Default RE: Fuji gasoline kill switch
Robinhood, You are right about the Fugi ignition throwing out RF. This is sometimes an indicayion that the ignition is going bad. Not in all cases though. I would look for another unit that would operate on the same terms as the 42% kill switch. I like the idea of the engine shutting down when the receiver has a loss of signal. Ed
Old 04-04-2008 | 10:46 PM
Hey guys new to gasser's need know how to wire a kill switch .
