Ignition Module Replacement
Old 02-04-2008 | 09:29 PM
dasintex's Avatar
My Feedback: (10)
Default Ignition Module Replacement
I am new to Gas Engines, and I will be running a Revolution 50 in a TF GS P-51; I have heard that the Ignition module that comes with this Engine can be unreliable, the module is made by the Engine's Manufacturer 'Cinemaster' and the module is called the 'RevMaster'; I want to go ahead and get a reliable Ignition Module as a direct replacement to the Rev Master; I would appreciate your suggestions; Make, Model, Source, etc; Thanks.
Old 02-04-2008 | 10:00 PM
AirWizard's Avatar
Default RE: Ignition Module Replacement
I have the Revolution 50 on my TF P-51.....I had to send the ignition back when I first got it.....the replacement runs good
Old 02-04-2008 | 11:08 PM
Buy a CH ignition , repairable to a certain extent if you hurt it.
Heaps better spark than the others i have tried
Old 02-05-2008 | 12:30 AM
BillHarris's Avatar
I'll second CH Ignitions.
http://www.ch-ignitions.com/
--Bill
Old 02-05-2008 | 02:52 AM
CH Syncro Spark is the top of the line replacement. CH also sells the RC Xcell ignition which is a close copy to the Syncro Spark. The RC Xcell costs a bit less and the availability is generally good. Call Terry at CH and have him set you up.
Old 02-05-2008 | 08:47 AM
The RC excell ignition is also available from Ralph Cuningham. He also does engine repair...ect. Capt,n
Old 02-05-2008 | 09:40 AM
That's right Cap't, one is an excellent product, the other is excellent service.
Karol
Old 02-05-2008 | 12:11 PM
He's also less expensive for the RC Xcell unit.
