Spark Plugs
My Feedback: (19)
ORIGINAL: TxDiveBomber
Don't hold me to it but I think the direct cross from champ is the NGK BPMR6F. I'm not 100% on that though.
TxDiveBomber
TxDiveBomber
AL
It does use the 5/8" tapered seat and the ignition is CH and has the rubber boots. I don't meanto start a "holy war", but I've had good results with NGK.
--Bill
--Bill
AL
A 7 or 8 heat range with Champion is equivalent to a 7 heat range with NGK. There is a heat range chart at the sparkplugs.com site.
--Bill
--Bill
My Feedback: (19)
ORIGINAL: fiery
Cross reference to RDJ7J is ...NGK BMR6F
The NGK BPMR6F has a projecting tip and as such is not the correct cross reference.
AL
I have a set of "current" Brison manuals in .PDF format, and it says:
>All new Brison engines now come with a short style NGK BPMR7A plug which accepts a >common rubber boot >and also the popular Bosch metal resistor cap.
FWIW
--Bill
FWIW
--Bill
