MVVS 58 Pro Power
![](/forum/images/badges/trading_plus_member.png)
I am thinking of getting a 2.6M Xtreme Composite Edge, would the 58 Pro be enough? people already with this plane fitted with a 100cc are getting 6700rpm with a 27x10 would the pro pull this with a tuned pipe?
Mike
Mike
Whoa! Easy does it, Mike.
The MVVS 58 cc is one powerful engine and slightly more so is its Pro version, but it does not quite make power like a 100 cc DA, or 3W.
A 27x10 narrow blade requires about 9 HP for 6700 rpm. It takes a very good 100 twin to do that, and I am not inclined to believe all those data without asking questions first.
To get 8 hp out of a 58 prosport, you would need to run it at about 7500 - 8000 rpm. That will not do with a 27x10, unless you use a reduction gear to get prop rpm down to 6500
Getting the engine up to 9 hp, even higher rpm is needed, and some modding (some call that hop-up) is in order.
Thanks for the feedback gentlemen, I suppose it was a forlorn hope, but I had to ask, the 58pro has so much power in my QQ Yak I was just looking for something to change it into, I am thinking of putting my MVVS 45 back into it to get the weight down and move the C of G back, so gentlemen whould you consider the maximum weight airframe I could put the 58 Pro into and still get pull out authority from a prop hang? dosn't have to be rocket like just authoritve.
Mike
Mike
ORIGINAL: BaldEagel
Mike
Mike
Pe
You have hit the weight right on the head, some of the guys with one all ready have got theirs down too 24Lbs with a 100cc in them, the only additional problem I can see is the weight bias towards the rear, I would probably have to install the elevator servos under the canopy and close loop them to the rear just to get some weight forward. Will keep you informed.
Mike
Mike
This is the first time I hear someone say the engine is too light???
I thought that a rearward bias is excellent for 3D. It is not my stuff, so I am just guessing. In a flight simulator, when landings get difficult and need down elevator, 3D becomes increasingly easier.
Thats the problem with the latest technology they can be too light as the aircraft manufacturers have not caught up yet, on my Xtreme Composite Edge 2M I had to put lead in the nose to get the recommended G of G, took it out after flying the plane and getting the C of G to where I like it.
On the 2.6M Edge some of the guys using 100cc engines have had problems getting the C of G forward enough, going to the extreme (pun intended) of putting trays in the cowl to take batteries to move the weight forward, that's why I am considering closed loop for the elevator instead of using the provided servo position inside the tailplane, this would move the servo weight forward close to the C of G, I know you know this, but for clarity an ounce at the back is worth appoximatley four ounces at the front (4:1 ratio between the C of G) so two Hitec 5955's which weigh four and one half ounces at the back would be the equivilant of eighteen ounces in the nose, that could be enough, what do you think?
Mike
Mike
zx32tt
The thing is I already have the 58 Pro in a grosly overpowered Yak and was just asking the question to see if it would work, plus I can get the 2.6M Edge at a very competitive price.
But and its a big but, I think I may go for a new engine its just a matter of whether I go for the new MVVS 80 or the MVVS 116.
Mike
Mike
I'll have the 116 with my current shipment that is being prepared right now. The 80 will take slightly longer.
I am afraid, that the 2.6 edge will be grossly overpowered as well if you go with the 116.
i think mvvs would have been better served making a 70cc .this size engine would not so closely mirror the power of the 116 .as the 80 cc most likely will.i think da sort of shot themselves in the foot making the 85 .it is a very nice engine but actually can replace there 100cc with less weight .i would like a engine that turns a 26x8 with athority.seem like this engine size keeps getting overlooked unless you go for a heavier 80 twin.Just a thought
there allways will be opinions but:
the 26 has 2.5 - 4.0 hp
the 35 has 3 - 4.5
the 45 has 4.0-5.5 hp
the 58 has 5-8 horses
the 80 will have 7-10
the 116 has 9-13
the 152 will be 11 - 15
I think this is a nice range with seamless overlapping of power when you want to choose between higher torque or higher rpm.
the 35 has 3 - 4.5
the 116 has 9-13
that is intresting. must have been the basis for da .but it does not take in to account torque of the engine.that is why the 80 single will have aprox the same usable torque as a larger twin.you know as well as i do engines do not live @ max hp.i think if you mesured the two torque curves at 6500 rpm. it would be a mutch closer race.remember effective load or (prop) is a constant .i cant just use a smaller prop to get higher hp (prop becomes less effective).if what you were saying were true thier would be a seamless range of prop choice.Anyhoo i love your engines and am in the process of getting the 58 .just trying to get that 70cc hole filled .it would be best to over lap torque curves.this would give best overall "usable" power (prop choice)
What is the suggested prop for MTW piped 58 prosport? Mainly 3D and I will start with MenzS woodie. Engine and pipe is still in Pe's shelf but ordering it during winter
Just collecting all the parts for the plane in advance. I haven't even selected the plane but something in 50cc class(Yak, sukhoi).
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
BaldEagle:
For your information:
I have the 2.6 Extrem Com Edge with a 3W85Xi, which is not a "light" engine, and I had to move EVERYTHING ahead to get the right CG.
If you decided to put a 80, you may need also a tuned pipe. Mine is using a ks pipe up to 120 cc The output is 6.300 rpm with 3W 28x10 wood prop, and that is more than enought.
Pe is right, with the 116 you will be overpowered, but it will be easyer to install. Ifyou put the 80, you will have to work in the plane. By the way, the tail of this plane is very heavy.
Hope this helps.
Regards,
Javier
Hope this helps.
Regards,
Javier
Javier
Thanks for the infomation, as Pe has said the 58 Pro is capable of producing 8HP under the right circumstances, I think what I am going to have to do is put a 28 x 10 on the 58 Pro and see what results I get at least then I will know one way or the other.
Mike
P.S. On my way to Spain next week for a short break, hope the weather holds out there.
Mike
Dar
Javier is talking about his 3W85xi that he has the 28 x 10 on and I am just wondering what revs the 58Pro would pull with that prop, I know the correct one for the 58 is about a 24 x 10, but I use a 22 x 10 three blade due to ground clearance and had to restrict the throttle to stop it going over 7500rpm which is where I chickened out, at the moment this is just an excersize for information.
Mike
Mike
Mike,
another pice of information is always wellcome ... BTW, this weekend I'm doing something similar. A friend of mine has a 58 just broken in. I have to tune a KS pipe for him, but the prop is Menz 24x10. I have the torque and power chart published by Pe for this engine, so, I will try to reproduce his numbers ...
Which part of Spain are you visiting? Weather in the south is very different from the north ...
Javier
I this the standard 58 or the Pro you are playing with, as it would be interesting to see the difference between the two, I have a JFX 24 x 10 I could put on and record the results, but this would be different to the Menz, but as you say any additional information is always good to have.
I am going to the South East area, near to the Costa's, not sure of the name as its a friend of ours that is taking us to their Vila, I will find out the name of the village and let you know.
Mike
Mike
