Sachs Dolmar
Old 04-11-2008 | 07:06 PM
vease's Avatar
Default Sachs Dolmar
I have a brand new sachs around the 70cc mark.
What actually is it? 70cc, 72cc, Not sure
And how do these engines compare in power to similar out there?
I just want to be confident in fitting it to a new model
Cheers all
Old 04-11-2008 | 09:56 PM
buck1856's Avatar
My Feedback: (49)
Default RE: Sachs Dolmar
Look at the front of the cylinder flange and see what numbers are there.They should be like 47NG,48ZG,51 or 52 plus a number or 2.These are the cylinder bore in MM"S.I have a sachs that has 47 so its 61cc.I have one that has 48NG,so its 62cc.If yours is a 70ish,i would say you should have a 52 with a couple letters after it.It should be about 72ccs.I have a A&M sachs engine with 44ZN wich means its a 52cc.
I have not run my 52 since i rebuilt it with my new tach but i was told by a very good and trusted source mine will run very close to a G62.Right now with ign RTF with out the battery and prop it weighs 4 lbs.
Old 04-14-2008 | 04:12 AM
gadix's Avatar
i know that most of the brison engine are based on the sachs - dolmar-makita
check kange to see a similar brison there
Old 04-14-2008 | 08:08 AM
My Feedback: (21)
70cc would be a Sachs 4.2 probably, depending on who made the engine it will be a very powerful and dependable engine. Check the end of the crankshaft for a dimple. A dimple means it is a Sachs crank and will be a very good engine. No dimple means it is not so good but may still be useable. Power wise my 4.2 is very comparable to a 3w 75.
Larry
Old 04-14-2008 | 11:30 PM
Brison bought out a an M sachs back in 93 or 94. The old A&M sachs use to like to go through the bearings and their cranks really don''t like ground strikes. but they are very powerful and should compete with any of the 70cc engines out there today
Old 04-15-2008 | 01:02 AM
buck1856's Avatar
My Feedback: (49)
Ya got that right about the cranks.My A&M,2 of them now,i bought cheap because the lower rod bearing went out.Both of the ones i bought didnt have the dimple in them so they where A&M"S own make.I simply bought a used sachs model 115 chainsaw crank and rod and exchanged them right out no problem.My second one i have has the same thing so im just waiting for the right parts to show up at auction again.The first one,case,crank,and rod only was $29.00 plus shipping.
Old 05-09-2008 | 03:50 PM
vease's Avatar
Just doing the final fitting of the engine now but have realised that I have 2 prop drive bolts missing. Anyone know what thread they are?
