gas tank setup
im familar with glow tank setups, but im new to gas and dont know how to set up my tank. do i still use two lines or what. thanks in advance guys for your help on this.
My Feedback: (67)
IA
Well you will want a fill line to the tank,and a seperate line from the tank to the carb, you can also have a third line used as a vent line that usually is atached to the firw wall and running out the bottom of the plane. I've also been told to have enough targon vent line to wrap around the tank so the engine wont lean out when inverted.
NEDYOB
NEDYOB
