SPE 40cc engine
Use the supplied prop bolt. There is also a prop washer that goes to the front of the prop with two holes in it that the bolt passes through. Drill out two small holes in your prop to match the washer and use the two allen key bolts to secure the whole thing to the prop shaft. All this shouild be covered in the instructions - or go the the BCMA web page for info. Not rocket science.
