Fuji BT 24 Magneto version max rpm
Old 07-06-2008, 03:33 PM
kwik
kwik's Avatar
Default Fuji BT 24 Magneto version max rpm
Hello;
I wonder what max expected rpm should be on a well known wood propeller.
Example Menz S 17x6 ( I got 7700 )
Menz S 16x8
Menz S 16x10 ( I got 6400 )
Some numbers here would make it easier to know whether its correctly adjusted.
Anyone?
Old 07-07-2008, 11:49 AM
Bax
Default RE: Fuji BT 24 Magneto version max rpm
You adjust the engine to be rich of peak RPM. Fuji doesn't have an RPM range specified. We normally load the engine to peak in the low-7,000's or so.
Old 07-13-2008, 11:46 AM
kwik
kwik's Avatar
With the max rpm stated above, my KMP Typhoon chrashed on takeoff . It wasnt enough thrust.
Afterwards I measured the thrust to be 4 lbs. That is nothing.
If I increase or decrease the H needle, the rpm decrease.....
Seems I cannot use this brand new Fuji.
