Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 where to mount a cdi ignition unit. >
Old 07-13-2008 | 03:54 AM
Default where to mount a cdi ignition unit.
Hi guys
I have a 46cc petrol engine that is going into my new model , iam new to petrols/gassers but have done a ton of glow motor running
I would like to know where i should mount the cdi ignition unit ( as fare a way from servos , receivers or batterys etc) iam running
at Jr x9303 2.4ghz radio if the helps
Any help would be great
cheers
Old 07-13-2008 | 04:07 AM
RC Extreme power's Avatar
My Feedback: (24)
Default RE: where to mount a cdi ignition unit.
If you have room, mount it on the side of the engine block and put the battery on the other side, Use Velcro and pull ties to mount it. Do not hard mount with screws.
Milton
Old 07-13-2008 | 02:34 PM
Is there a reason for not using screw mine has little tabs on the ends looks like for using screws
Old 07-13-2008 | 02:58 PM
VIBRATION
Old 07-13-2008 | 04:03 PM
My Feedback: (24)
ORIGINAL: rlmcnii
VIBRATION
And if you have a mishap you will have a better chance of not breaking the ignition box.
Milton
Old 07-13-2008 | 08:27 PM
ok thanks guys
Old 07-14-2008 | 03:36 PM
ORIGINAL: tocpilot
Hi guys
cheers
Please forget all you know about glow engines. Gas engines are a different breed and need their own approach. Small fry is glow, and about 26cc and upwards is the realm of gas engines. Larger engines are larger stompers, so the propulsion pulses are heavier. You need to construct your plane and parts accordingly. Mount electronics in foam, so it is protected from the large vibration pulses, which are mainly there because of the very light airframe structures now abailable, and becoming increasingly popular.
Velcro mountings are very effective in protecting your equipment. So is foam mounting, though it has the drawback of less cooling.
Learn how to handle vibration prone applications. Learn how to live with, and prevent radio interferance. Learn about mufflers and carb tuning. Once you do all that, you'll never look back.
