RCGF Engines
#3376
ME
RE: RCGF Engines
ORIGINAL: stangevil29
I wasnt getting after you I was just stating what I had with my engine. I was afraid that I had gotten something different than what I needed. But, anyway yes the standoffs are tapped on both ends for the 10-32.
The standoffs are really 5mm x 0.8, real close to 10-32, but a 10-32 will fit a bit loose, could strip the threads when tightened. Found this out making some standoffs and taping for 10-32 and the bolts for original standoffs fit so tight that I knew something was not right.
Steve
#3377
RE: RCGF Engines
Not offended at all steve
I ran the RCGF again today with a Zinger 16x8 I have and I got it up to 7,650rpm peak and backed it down to 7,550rpm. Idle is solid at 2,200rpm. I can idle it lower, but it shakes the airframe a fair bit and at 2,200-2,500rpm its quite smooth. Smoother than I expected an engine of this size to be.
Are those numbers ok for that prop?
The engine is running smoother each time I run it.
Also having hassles with the fuel tank. Ihave pulled it out and pressure tested it twice now and can't get so much as a squeak out of the tank and fittings. Yet when Irun the engine for a few minutes Iget fuel on the outside of the tank inside the fuse. The tank stopper is directly behind the carb about 1.5" away. Iknow the gas engines don't spit fuel like the glow engines while they are running so could this fuel be coming from priming the engine and it spitting or dribbling out of the carb onto the tank this way?
#3379
RE: RCGF Engines
It is one of the older engines and I am told they arent as strong as the newer ones.
Thanks for that Super08. I will keep an eye on it and see how it goes.
#3380
My Feedback: (12)
MT
RE: RCGF Engines
ORIGINAL: VeeAte
Shane
#3382
RE: RCGF Engines
Yeh I agree. I had another look over the engine setup and I think I might need to make some space for air to get to the carb. There is a hole through the firewall directly behind the carb opening and then about 1.5" away is the fuel tank. I have a couple of fuel lines near there too so am thinking it can't breathe perhaps ?
I figured out where the fuel is coming from too. The stopper in the tank was shredded! It's a Sullivan stopper. I got the gas conversion kit.
Could this have been caused from tightening the screw too much on the stopper? It's broken apart on the part of the stopper that is inside the tank.
#3383
My Feedback: (12)
MT
RE: RCGF Engines
I have damaged the stoppers from tightening them too tight, especially if it has the metal backside. Plastic ones will usually strip before you get them too tight.
Shane
Shane
#3384
RE: RCGF Engines
mjohnst3, my plane manual says to use a magnetic ring/RF filter on the servo lead. 2 types are made that i found on horizon hobby.
the ring type by Align 3 for $1.99 also by JR 2 for $8.99 and a snap type made by JR 2 for $15.19
i think the Align ones might be small since 3 are only $1.99???? good deal if they are the same as JR's
Align ring http://www.horizonhobby.com/Products...rodID=AGNR1000
JR ring http://www.horizonhobby.com/Products...ProdID=JRPA029
JR snap style http://www.horizonhobby.com/Products...ProdID=JRPA028
#3385
RE: RCGF Engines
ORIGINAL: Mr.FiberOptic
#3386
IA
RE: RCGF Engines
If you feel you MUST use a filter, just go to Radio Shack...save some money. I would personally find and resolve the interference problem, rather than try to filter it out on its way to my system.
#3387
RE: RCGF Engines
ORIGINAL: VeeAte
Karol
#3388
RE: RCGF Engines
goirish it goes over your servo wire lead to stop interference. if you setup the throttle linkage correctly you might not need one.
that is just what my manual said to use. by the way ive never tryed one.
#3389
IA
RE: RCGF Engines
ORIGINAL: VeeAte
...also if you have a deteriorating sullivan stopper, and without a very good filterclunk in your tank, you will also very likely have unwanted debris in the internal carb filter screen. I wouldn't wait to find out if you have a problem after knowing your stopper was coming apart. It would be worthwhile to have a quick peak and clean, while you are digging in and fixing things.
#3390
AZ
RE: RCGF Engines
For those that have set up a choke servo on the 26cc, how are you doing it? I understand the throttle arm connection because you can take the carb arm off and place a servo arm on top of it. Since the choke arm is different I cant come up with a idea to connect a servo to it. Thanks in advance.
Stangevil29
#3391
RE: RCGF Engines
Thanks karolh and arobatx.
The carb screen and inline filter were my next item to inspect. The Sullivan stopper lasted about 4 tanks. Its in about 4 pieces and looks eaten out around where the copper fuel lines went through it.
I will order a dubro stopper. Thanks for the help.
#3392
RE: RCGF Engines
For those that have set up a choke servo on the 26cc, how are you doing it? I understand the throttlearm connection because you can take the carb arm off and place a servoarm on top of it. Since the choke arm is different I cantcome up with a idea to connect a servo to it. Thanks in advance.
Stangevil29
Stangevil29
#3393
VA
RE: RCGF Engines
I have the 26cc mounted on a GB Obsession. 2 -3 hrs of flight time. Picked up two new props at Nall last week. Prop data is as follows:
Xoar 17x6: 8400/ 1900-1950 (wood laminated)
APC 17x6: 8300/ 1900
APC 18x6w: 7900/1800
AUW (dry) 11-2oz, 160oz tank., Amsoil ~60:1
Wonderful engine. Still having a bit of trouble on cold start. It won't draw enough to pop w/ choke. Hit it w/ the starter and it is fine for the rest of day, hot or cold. Starts w/ 1 hand flip. Fill the tank and a way you go. Very fugal on gas. Still don't have 2 gallons through it.. Will post pics of the setup. The prop change did not affect hovering the Obsession. The APC will sort of climb out??? Very slowly.
Will be looking for another plane. Bob
#3395
RE: RCGF Engines
good idea to just leave the little choke arm instead of removing it.
just drill and tap for 4-40 screws and attach a servo arm to the little choke armjust like with the throttle
#3400
My Feedback: (9)
WA
RE: RCGF Engines
I'm replying to my own advice here. I have been recommending that folks use the Hayes medium neoprene as a clunk line. I recently found that the Hayes medium neoprene line had broken at the clunk inside the tank, twice! So now I've gone back to yellow Tygon for my clunk lines, and will just replace them yearly. The felt clunks I use will provide plenty of weight to move the line around in thetank,but should stay firm enough that theclunk won't be able to come all the way forward in the tank. The mandated replacement will be part of my annual maintenance.
Sam
Sam
