Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 MVVS ignition light / LED not working >
Old 09-16-2008 | 01:32 PM
v8mini's Avatar
Default MVVS ignition light / LED not working
the LED for the ignition has stopped working on my MVVS 26. normally flashes when powered up, but since crashing my Showtime 90 a few months ago i have just rebuild another and found the LED doesn't flash any more.
the ignition does work as i have started the engine, and if anything it seemed to start easier.
any one know what to replace the LED with, and particular type voltage ect. or whats the best way to check the one i have is actually blown. can i just ad voltage if so how much ?
Old 09-16-2008 | 02:29 PM
Default RE: MVVS ignition light / LED not working
Hi
Talk to John at Puffin Models They have a website They are the dealer for MVVS Engines
He'll keep you right
Regards
Styk
Old 09-16-2008 | 02:33 PM
v8mini's Avatar
might try that, i did actually get my engine from them.
but if anyone does have LED spec's please advise
Old 09-16-2008 | 05:21 PM
BaldEagel's Avatar
I took the LED light out of a car cigar lighter accesory plug and that works OK on my MVVS 45 ignition which is the S type that uses a 2S LiPo 6.5v too 8.4volts.
Mike
Old 09-17-2008 | 11:32 AM
v8mini's Avatar
i did try to call Puffin Models up first thing this morning, but the chap i needed to talk to wasnt there until this afternoon.
i popped in to Maplins and got a LED and it works as before
the one i got was a N45AT and looks the same as the old one, and only cost 69p
[link=http://www.maplin.co.uk/Module.aspx?ModuleNo=35746&criteria=5MM&doy=search]N45AT 5mm clr red 4cd LED[/link]
