Porpeller mounting orientation
My Feedback: (67)
I'm a newbie to gassers. What is the correct method to install a multi-hole propeller on the engine. Should drilling be done such that the prop can be installed when the piston is at TDC? Should it be installed @ 2/8 o'clock? Does it really matter?
tia
tia
DC
Doesn't really matter, but straight across with the piston at TDC will keep the prop from breaking if you have to land dead stick and bounce a little...
Normally you mount the prop at the 2/8 o'clock position with the piston at tdc. This is the best position for hand starting the motor. It also aids in the prop stopping between the 2 and 4 o'clock preventing a prop hit on landing. Everything should be fine!
