G26EI THROTTLE ARM
Old 09-29-2008 | 02:59 PM
Default G26EI THROTTLE ARM
Hey guys, when i installed my g20 I made a arm to screw to the original crank and it works well. My g26 came with a r/c arm which I installed with no problems. The only thing now is the butterfly can actually go passed full open. I adjusted the radio to just shy of wide open but have not run it yet. What will happen if you actually go past wide open.... Any harm or just poor running....?
Old 09-29-2008 | 03:08 PM
Default RE: G26EI THROTTLE ARM
Some have claimed that slightly beyond 'full open' offers a few more rpm...never tried it. The engine will respond pretty softly to small changes in disc position the closer you get to wide open anyway, so get it close by eye, and you should be fine. The important thing is that you have it closing the proper direction, otherwise the disc valve will not seat properly or idle correctly....etc. After a while, and some vibration, the disc will no longer fit correctly and you could see trouble even if rotated to operate in the correct direction.
