Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 what to replace nitro Webra 61 engine with >
Old 10-11-2008 | 04:57 PM
Default what to replace nitro Webra 61 engine with
hey
i got given a heli boy chopper and but the crack shaft came broken and as u can no longer get parts readily anymore i was wondering if there was a same size engine i could replace it with that would be same overall size and have same sort of mounting holes can anyone suggest a cheap but good motor that would replace this Webra 61
thanks heaps
Old 10-11-2008 | 05:42 PM
Default RE: what to replace nitro Webra 61 engine with
anyone any suggestions please
Old 10-11-2008 | 06:32 PM
http://www.chiefaircraft.com/rcmsec/...Hacker-50.html .Spend lots more time flying. Actually I think the new 49" and 51 inch E planes fly so good there's no reason to go much larger. (as in Sebart and Cermark Sukhoi's), Till you go gas and there they start in the 85+ inch span. And 50cc motors.
Old 10-12-2008 | 07:30 AM
Iflyglow's Avatar
My Feedback: (79)
Altavillian,
I think you missed the boat on the question. He wants to know what glow engine will replace a Webra .61 in a "OLD HELI BOY" Helicopter.
Old 10-12-2008 | 11:03 AM
Antique's Avatar
See if you can get some of the old timers to look through the stuff on the shelf in the garage...I had a .61 blackhead, maybe the crank is the same...The engine died when one of those little tiny wrist pin clips came out of the piston and destroyed the cylinder wall and piston...Maybe it's still here somewhere, will look...[8D]
Old 10-13-2008 | 02:45 AM
anymore suggestions is there any shafts that are similiar is there any motor anyone could suggest
does any one have a spare one or anything
any help would be appreciated
