clockwise dl50
hello. i was just wondering if a dl50 can be run clockwise. i have a ziroli p38 which i plan to run a pair of dl50's. the real p38 has one engine running counterclockwise and one running clockwise. can this be done with the dl 50's?
My Feedback: (13)
OR
I don't know how the prop adapter is attached on that engine (I know it has 4 bolts holding the prop on, they should be fine turning the other way), but if it's held on by a bolt or nut of some sort, be sure to loctite it well, otherwise the only thing that needs to be changed is the timing, change it to the other side from top dead center (probably either 28 or 30 degrees), with piston ported engines the only thing keeping them running in the right direction is the timing... nitro engines have a port in the crank, so they're more picky... I'd say the hardest part would be finding a matching reverse rotation prop...
My Feedback: (98)
ORIGINAL: flystwinns
Both turning opposite negated the critical engine situation. If they were same direction, clockwise from the cockpit, the left would have been critical. Then again, with props that big and that much torque I would not have been one to enjoy trying Vmc on the critical engine....
My Feedback: (98)
ORIGINAL: Tired Old Man
It's a good thing the Germans never learned to stop putzing with things and just make a lot of them, only one exception was the 109 which they made 33,000 of.
My Feedback: (98)
ORIGINAL: Flyfast1
Tell me about it. My 1/4 scale ME109G is the trickiest plane I've ever flown. In addition to the difficulty in making straight takeoffs because of the narrow gear and the angle, the scale tail feathers make landings very tricky indeed.
-Ed B.
-Ed B.
