dl50 muffler
Old 10-22-2008 | 06:23 PM
ramduster's Avatar
Default dl50 muffler
I need a new muffler for my dl50 the is like or similar to the stock muffler that comes with the dl50 so what other engine mufflers fit the dl50.
Old 10-22-2008 | 06:47 PM
Default RE: dl50 muffler
try here, They may have what you are looking for, Its my understanding that the DA50 muffler is a direct bolt on.
http://troybuiltmodels.com/newsite/p...s_da.html#ic50
Old 10-22-2008 | 06:49 PM
It's my understanding the G-62 bolt pattern is also a match.........
Old 10-23-2008 | 03:44 AM
ramduster's Avatar
Thanks guys just what I needed to know.
Old 10-23-2008 | 08:47 AM
The DL50 muffler is the lightest of its kind, available for $35 from Bob at DLUSA. The initial problems seen with weak seems on the original muffler appear to have been worked out, as I have been running this muffler on my G62 all summer. The DA50 muffler will be stronger, a little heavier, and a little more expensive. The pitts mufflers can be significantly heavier than the OEM side mount DL muffler. So beware of balance issues if you switch from one to the other. My most recent slimline weighed in at 11oz, and the DL, with mounting bolts, no gasket (as installed) weighs a bit less than 3oz. 1/2 pound is a big difference so keep that in mind.
