US25 fuel hookup?
My Feedback: (7)
AR
US25 fuel hookup?
Hello my friends
I have a question on fuel line hookups for the US25..Theres two fuel inlets,one close to the engine block the other is near the primer bulb..Is the one near the engine block for main fuel inlet?
and does the line near the fuel bulb the return line?
Let me know how u hook these lines up..Its my first gas engine..
Thank u for ur help..
US25 fuel hookup?
hmmm
ive been doing a lot of research on hooking up my walbro carb as well and your sounds like the easy one to hook up.
the primer bulb goes back to the tank vent line and the other nipple is the incoming fuel line.
if im wrong someone will jump in, but i think thats correct.
MS
US25 fuel hookup?
my US41 only has one nipple on the walbro carb (fuel line in). other than that, my tank has a vent which also serves as an overflow. I thought gassers did not need back pressure and muffler back pressure was a BIG no-no due to excessive heat which would be a fire hazard! mine runs fine. am i set-up correctly?????????also mine does not have a primer bulb.
