Stihl 28cc, Carb change
Old 10-26-2008, 04:10 PM
Mak Gyver
Default Stihl 28cc, Carb change
I have a Stihl chain saw engine(28cc) that I converted over for air plane. It has a Zama carb with only high adjustment and over flow. Wanting to know what I would have to do to convert to a Walbro carb? How do I get the right size? Can I cross refernce the numbers off my carb to a Walbro?
Old 10-26-2008, 04:19 PM
pe reivers
Default RE: Still 28cc, Carb change
There is no cross reference, but for a 28cc engine, the Walbro WT481 would be a good idea I think.
PS
Zama carbs are not bad at all, so if you can get a two needle Zama, you are all ready to go.
Old 10-26-2008, 09:36 PM
buck1856
My Feedback: (49)
buck1856's Avatar
Default RE: Stihl 28cc, Carb change
I have a WA-200 walbro-2 needle on mine.72-7400 with an APC17x8.Ch ign,no advance or synchro spark.Set at 28 BTDC.
