q-100 bent crankshaft (help)
Old 05-28-2003, 11:04 AM
lloyd allen
Default q-100 bent crankshaft (help)
crankshaft in my q-100 is slightly bent from crash,doz any one have an idea on how to fix,without total replacement.
Old 05-28-2003, 11:57 AM
tkilwein
tkilwein's Avatar
Depending on where bent, I have used a pipe with a plastic insert to bend the threaded portion a little then I check it with a dial indicator, by removing the plug and turning the shaft. The dial indicator will let you know which side to bend. I get mine within
1 thousand this way.
Hope this helps.
Old 05-28-2003, 10:22 PM
lloyd allen
this sounds like a great idea ,do i have to take the crank shaft compleatly out the engine and is a dial indcator somthing a lo cal machine shop would have ?
