St3000 Smoke Setup
TX
Is a ST3000 a good motor to use with a TME smoke pump system? If so, any advice on getting it to run right? Should we invest in a Slimline smoke muffler with a coil?
Coverdup
Coverdup
I use a smoke muffler which has internal heating coils before the smoke (50/50 ATF & Diesel) is injected into the muffler which is on a ST 3250. The pump I use is the TME system and the result is very satisfactory. Hope this helps.
Cheers, Tom
Cheers, Tom
