Any way to test Ignition unit?
Old 12-28-2008 | 06:55 PM
Default Any way to test Ignition unit?
Hey everyone. I have a Venom 45 gas engine. Have not been able to get it to start. Checked that the timing is correct. Getting gas, and not flooding. I know the ignition unit has been in a crash. Is there anyway to test the ignition to see if it is working? Thanks!
trey
Old 12-28-2008 | 07:01 PM
Ram Jet's Avatar
Default RE: Any way to test Ignition unit?
Yep, pull the plug, reconnect it to the secondary/spark plug wire, ground the plug and turn over your engine. If you see a blueish white spark across the plug gap you have spark - but that doesn't mean it's sparking when the piston wants it to. It is a start though.
Bill
Old 12-28-2008 | 07:02 PM
My Feedback: (31)
pull the spark plug out and then plug it back into the ingition and lay the plug on the motor were u can see the bottom of the plug. spin the engine over very slowly with ignition turned on and see if it sparks that plug.
Old 12-28-2008 | 07:03 PM
Thanks man. Tried that the other day. No spark at all. Didn't know if that was a good diagnosis, I've been told that on these engines, you can't see the spark. I found that hard to believe.
Old 12-28-2008 | 08:22 PM
AirWizard's Avatar
No spark no fire.....
Old 12-28-2008 | 09:59 PM
figured it out, turns out the sensor was bad. swapped it with a new one.
Old 12-28-2008 | 11:32 PM
My Feedback: (31)
U Da Man![8D]
Old 12-29-2008 | 09:53 AM
Hah! Pretty sure I got lucky.
Old 12-29-2008 | 12:09 PM
RC Extreme power's Avatar
My Feedback: (24)
Here is a neat little tool for testing ignitions, I think it will work with RC Xel also.
54. Ignition and pulse switch tester pix .................................................. ......................... $21.95
http://www.ch-ignitions.com/#cat
Milton
