Kill switch for Riobi 31
Old 06-08-2003 | 09:54 AM
Default Kill switch for Riobi 31
Can anyone tell me what amperage SPST kill switch I need for a Riobi 31 gasser. Thanks.
Old 06-08-2003 | 10:13 AM
Jemo's Avatar
You can use just about anything.
The switch is open while the engine is running, it just allows you to ground it to shut it down, just like if you took the wire and touched the engine with it.
Old 06-08-2003 | 11:16 AM
Make sure you use a slide switch and not a toggle switch. Toggles have a habit of vibrating apart over time.
