Super Tech Universal 2 cycle oil for air cooled same as Pennzoil air cooled???
Was at Wally World today looking at the oils and noticed the Super Tech Universal 2 cycle oil for air cooled engines. I remember looking at the oil awhile back noticing that it was manufactured by SOPUS Products (Shell Oil bought out Pennzoil-Quaker State, make Pennzoil products, and now are called SOPUS Products just look on the back label of a new bottle of Pennzoil...) but now it says "manufactured in the USA for Wal-Mart Stores blah, blah"... I then looked at the back and saw the emergency number (1-800-782-7852) and googled it and came across links for Shell, Aeroshell and Texaco Lubricants.
My question is could this be the same as Pennzoil air cooled oil ??? If so it is a lot easier to find then the regular Pennzoil...
Any hard info on this ??? I tried doing a search and got a bunch of dead ends..
[link=http://www.pzlqs.com/brands/default_brands.htm]SOPUS Products page...[/link]
OK
RE: Super Tech Universal 2 cycle oil for air cooled same as Pennzoil air cooled???
I know a lot of folks that are using the Wal Mart oil in their 2 stroke engines with excellent results.
TX
I used that Super Tech oil for initial run-in of a SV 26, mixed at 32:1. It sure threw a lot of black gunk out the exhaust. A clubmate who runs a boat repair shop told me the Pennzoil 2 cycle oil does the same thing.
Anyone care to share their experience with the Pennzoil?
CR
CR
My Feedback: (117)
What percent of mixture are you using? Thanks. Brian
ORIGINAL: mrbigg
I've never experienced black gunk out of the exhaust with the use of Pennzoil Aircooled. I have not used Super Tech 2 Stroke but have used the 10W30 car oil with good results.
My Feedback: (21)
40:1 is the mix I used. I have mixed at 32:1 for a couple of gallons and did not notice a whole lot of black gunk either. I do tune my needles though and check the results by reading the sparkplug(s). I consider this a requirement of 2 stroke tuning. Praise God, I've never locked one up or melted one down.
CA
I do not know if Super tech universal is the same as Pennzoil, but I pretty much can guarantee that Sthil ultra is made by Castrol.
I run Pennzoil at 32:1 and I do get those black specks, but not really bad.
HI
here's the data sheet for pennzoil air cooled...now just have to find the data sheet for super tech, and see if they match up...btw, i can put my car in neutral and roll down the hill to my neighborhood wally world...lol...ken
http://www.pzlqs.com/Tech/Pdsheet/Do...eAirCooled.PDF
My Feedback: (117)
Thanks for that. I have been running Opti 2 from the lawn and garden shop. Also use Penzoil at 40:1 and I do get some black specks with both, but not bad. Brian
ORIGINAL: mrbigg
ORIGINAL: kenhiraihnl
Yeah I found that but finding the data sheet for the Super Tech is the problem...
I see you are from Hawaii...in the pic is that the Arizona Memorial top right???
HI
hi sportflyer3...that's the pearl harbor 'boneyard' in the upper right (where the navy stores decommissioned ships)...here's a pic taken in the direction of ford island, the arizona memorial, battleship missouri, and the floating causeway...taken with my multiplex easystar w/ blip camera...btw, that large, white-roofed shopping center at center right has a 'don quijote' department store that carries pennzoil air cooled...ken
ORIGINAL: SportFlyer3
WI
My local Walmart has the Pennzoil Multi-Purpose TC-W3. I'm building a Spacewalker that will be powered by a DL-50 and am wondering what oil to use. I went to Pennzoil's site and the datasheet for the MP TC-W3 pulls up one for their Outboard oil for some reason. I'm wondering if the Outboard oil is the same formula as the MP TC-W3 or if it's just a glitch on their site. It does say it is suitable for other applications requiring TC-W3. Anyone know what the difference is between the MP TC-W3 and the Air Cooled oil?
Mike
Mike
OK
Whats the difference? As a matter of fact, Quicksilver states on their bottle " good for air and water cooled engines. There is avbsolutely no sound info that states there's a difference. Why don't you go to Walmart and get some and try it? Grimiln x has stated many times that Quicksilver is the best of all oils for our engines, and Lawn Boy and PEENZOIL are the worst. His info comes from a dyno and a lot of testing. How long are we gonna bash this around?
CA
Quicksilver, etc. maybe, but Pennzoil tcw3 NO. Stihl ultra, from what little I know leads the pack too, that will be the next one I try.
Not bashing anything around, oh and yes, walmart oil ain't to bad either.
TX
Dunno if I said so earlier but I just tried Valvoline air-cooled multi-purpose oil in the first run of my G38, mixed at 32:1. Ran good, no oil flecks. Found it at Autozone.
CR
CR
TX
The problem is that the Supertech bottle doesn't tell you who made it; so no way to find a data sheet. Grrrr.....
CR
CR
So rather than beat heads against a wall trying to figure out who makes what and how it qualifies, why not use something that you know works? Or is it that you might save 50 cents a bottle with the unknown stuff?
If it's about the money you're involved in the wrong endeavor and need to find something more inline with your long term budgeting......
My Feedback: (19)
You guys didn't look hard enough if you didn't find the MSDS for the two.
Judge for yourself. I'm just adding fuel to the fire.[sm=rolleyes.gif]
[link=http://edfinfo.com/x/temp/MSDS_Pennzoil_Aircooled.pdf]MSDS Pennzoil Air Cooled[/link]
[link=http://edfinfo.com/x/temp/MSDS_Super_Tech_Universal_2_Cycle.pdf]MSDS Super Tech Universal 2 Cycle[/link]
My Feedback: (198)
Good to see such similarities in the contact info....that's pretty interesting.
But does it mean Wally World oil and Pennzoil oil are the same oil or just that they have the same contact information on their MSDS sheets?[X(]
I *STILL* think Orville Redenbacker Pour Over is just "THE BEST"...... it goes with ANY raging and timeless, meaningless and uninformed speculative outrageous debate of subjective opinions on RCU on any forum.
Almost like salt.....can darn near be used on anything.
I wonder if we could just use that funky nasty black used oil out of our car engine crankcases? Probably wouldn't make a whipstich difference except to the sticky rings....
ORIGINAL: jack1933
ORIGINAL: gkamysz
Hrmm...same info on the viscosity, toxicological info, and same contact info down to the PO Box. When I run out of the Pennzoil I may do more digging and may switch. It's not that I want to save a few pennies. I just don't want to run all over the countryside looking for Penn if the Wally brand is similar or even the same... I live in a small town and have to travel to the bigger city to find Pennzoil and even then I have to run all over town to find the stuff. A Wal Mart is only thirty mins down the road in any direction except due south. (I stay on the bay...)
Thanks for the info...
LA
Ive used the stihl oil after about 10 gal I dissasembled the engine very clean internals just a residue on top of piston no scuffing of psiton or cylider walls no significant carbon buildup
