SV-26 carb problems
Old 02-17-2009 | 10:24 PM
jstanton's Avatar
My Feedback: (14)
Default SV-26 carb problems
I am having trouble with my WT-731 carb.[:'(] I can get the engine to start and run from mid-range to Top end. I can't it to idle. [:@]I have replaced all of the seals and diaphram's and it still won't idle.[:'(] I have installed a choke and I have to keep the choke at half just to keep it running at all. I would like to get a new carb, but the WT-731 that is on the engine is no longer avalible. I have tried a WT-433 and a WT-622, but I cannot get them to even pull fuel into the carb. The pulse from the engine to the carb is working just fine. Does anyone know what Walbro carb I can use on the SV-26 or what is the Walbro carb the new SV-26 enignes are using?
Old 02-17-2009 | 10:36 PM
soarrich's Avatar
My Feedback: (98)
Default RE: SV-26 carb problems
Check the crankcase gasket again. I've worked on several of these and the gasket always blows out, and will cause the problem you describe.
I don't think it's a carb problem.
Old 02-17-2009 | 10:39 PM
jstanton's Avatar
My Feedback: (14)
Rich,
If the crack case gasket is bad do you know where I can get another one. I got this engine from hobby city and they no longer carry it.[:'(]
Old 02-17-2009 | 10:45 PM
soarrich's Avatar
My Feedback: (98)
ORIGINAL: jstanton
Rich,
www.lsproengines.com/ used to sell them as their 26cc, I think Larry still has some gaskets for it. RCS may sell them now. I just bought Permatex 2 cycle crankcase gasket, it's a red jell made for this.
Old 02-17-2009 | 10:53 PM
jstanton's Avatar
My Feedback: (14)
Rich,
Thanks for the help. I Give RCS & LSproengines a call.
Old 02-18-2009 | 08:11 AM
mrbigg's Avatar
My Feedback: (21)
WT 694 on my RCS SV 26.
Old 02-18-2009 | 08:36 AM
jstanton's Avatar
My Feedback: (14)
Mrbigg,
Thanks for that info. I'll look into a WT-694
Old 02-19-2009 | 12:21 PM
jstanton's Avatar
My Feedback: (14)
I took the carb off the engine and checked the manifold gasket and case gasket. The case gasket was good, but the manifold gasket did not look to good so I replaced it. I also checked the reed valve for any wear. The reeds looked good. I went ahead and replaced the gas screen in the carb and used my aircompressure along with carb clearner to blow out all of the little gas channels in the carb. I have put everythibg back together and now well see what happens. My carb that came with the SV-26 is a Walbro 731 and it has a 9.55mm venturi. The WT-694 that Mr Bigg has on his SV-26 has a 12mm venturi. If this does not work I am going to try the WT-694 carb
Old 02-19-2009 | 03:22 PM
The reed block on my engine had a couple of small raised edges where the screws to hold the reeds down had been screwed in a little too tight. Hope that explains it.
Anyway, I took it all apart because I could see that the reeds were just not quite laying flat against the block.
A few minutes with some superfine wet and dry sand paper got them good and square (flat) again. I did a check after re-assembly by wetting the contact surfaces between the reed and block and could see it was good now.
I did this before ever running the engine, so I don't know what effect it might have had, but figure it was better to catch it now rather than later.
I also found 1/64" thick gasket material by Felpro at NAPA 18"x36" for $4bucks. This was the thinnest fuel compatible gasket material I have been able to find locally.
Old 03-16-2009 | 02:34 PM
Hello, where can I find Wabro WT 694 carburetor replacement parts, specially the throtle arm, for my RCS SV26 gasoline engine?
Thanks, Isaias G.
Old 03-16-2009 | 09:47 PM
Ed
" Does anyone know what Walbro carb I can use on the SV-26 or what is the Walbro carb the new SV-26 enignes are using? "
Received my SV-26 just 2 weeks ago, and it came with a 694.
Runs good, nice idle.
Ed
Old 03-17-2009 | 08:11 AM
mrbigg's Avatar
My Feedback: (21)
ORIGINAL: lechuza
Thanks, Isaias G.
Look in the classifieds here. Ken Lambert sells machined aluminum throttle arms.
Old 03-17-2009 | 08:20 AM
jstanton's Avatar
My Feedback: (14)
ORIGINAL: lechuza
Thanks, Isaias G.
You can try http://www.brillellicustoms.com/ for you throttle arm. Mark makes these nice aluminum throttl arms that will fit any walbro carb.
