Ignition wiring
AR
Hello all,
was wondering if someone can help me figure out how to wire the ignition on a G38 I believe it has a Bosh ignition that was a retro fit. I have a 6 volt batt and a switch already mounted just need to know were to go from here ? also how to set up a kill switch...thanks
ORIGINAL: RuninWideOpen
Hello all,
Hello all,
battery
switch
optical kill switch
ignition
FL
The Zenoah is a magneto driven CDI ignition, doesn't need a battery. You will wire the kill lead (usually the loose lead on the CDI) thru a kill switch to ground. Good luck, red
