GRpro20cc gas engine
Old 04-08-2009 | 02:41 AM
Default GRpro20cc gas engine
This engine is speciall designed for small air plane,which is with good performance and quality.The detailed technical data as belows:
GRpro20cc: Capacity:20cc
Parameter:
Type : 2 cycle piston valve type gasoline engine for airplane
Piston displacement Cylinder (cc) : 20cc
Bore x Stroke (mm): 30mm*28mm
Carburetor : Walbro Pump(made in Janpan) & Made in china (Diaphragm butterfly valve type)
Ignition : DC-CDI (Computer Controlled auto advance,electronic ignition system)
Power supply: 4.8-6V
G.Weight: 1000g( including ignition and muffler )
N.Weight: 800g(not including ignition and muffler)
Maximum Output : 2.2 hp /1.64KW
speed rang : 1500-9000rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1
(90% high otcane unleaded gasoline,Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 15*6 9500rpm ,16*6 9000rpm (Two leafs prop)
Cooling System : Air Cooled
Remark: the gross weight include weight of individual Packing
ID:	1175565   Click image for larger version
ID:	1175566   Click image for larger version
Old 04-08-2009 | 09:00 AM
soarrich's Avatar
My Feedback: (98)
Default RE: GRpro20cc gas engine
Beautiful looking engine.
If you need a tester in the USA I have a plane that it would power nicely just waiting for an engine.
Old 04-08-2009 | 09:37 AM
aussiesteve's Avatar
Looks surprisingly similar to the RCGF one to me
Is that who manufactures it for you? - I know they do OEM for many companies.
Old 04-08-2009 | 10:44 AM
Who will be selling this engine? Will it be someone here in the US or overseas mail-order?
Old 04-09-2009 | 02:32 AM
Give Henry a call,
he has the RCGF/Aerovate 20cc rear carb. Better backup and sourced locally.
www.zrcgf.com
Old 04-09-2009 | 06:52 AM
TomCrump's Avatar
ORIGINAL: spasmatic
I would assume that Knox Hobbies would be the distributor. http://knoxhobbies.com/shop/catalog/...d0d03ff396c99b
Good people to deal with.
Old 04-09-2009 | 11:25 AM
Yep - seen all those somewhere before in a past life - as a distributor for the manufacturing company
