Zenoah GT80 carburetor leaks
My Feedback: (17)
AZ
Can the usual fuel leakage from the GT80 carb be fixed using another Walbro model, maybe the the SDC80?
Will this increase fuel efficiency?
Thanks!
Thanks!
WY
RE: Zenoah GT80 carburetor leaks
The Zenoah Gt 80 carbs don't have a history of leaking fuel. BUT they do have a history of spiting fuel out the carb if you try to run them to slow.
An SDC 80 would suffer the same problem.
Easy answer is to go to a smaller prop or use a V stack, and adjust the HS needle carefully
My Feedback: (19)
ORIGINAL: Yak13
Thanks!
Thanks!
