DA-85 ignition light
Anyone know how many times the ignition light should blink when it is turned on? Mine blinks once which is different than my other engines. It is getting fuel...just wondering if the ignition is firing properly. May need to get a new plug. It flooded the first time I tried it. Only got about 5 flips before it flooded. Trying like hell to get this engine started and broke in for next weekend. Having one heck of a time with it. The evo was much easier to start up the first time as was the off brand engine. This one is being a pain in the backside.
Kevin
Kevin
Yeah....just realized that the light I hooked up is for the ignition cut off...not the ignition. My other engines have a light with the ignition...which led to my ignorance.
Kevin
Kevin
Problem solved. Turns out the switch I selected for the cut off (which is momentary) was in need of reversing. Thought it was funny that the cut off light would go on and off right away. First one with a cut off. Now I plan to put them in the others as well. Nice feature.
Kevin
Kevin
