Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 engine generated interferance on 2.4 >
Old 04-05-2010 | 03:34 PM
Jezmo's Avatar
Default RE: engine generated interferance on 2.4
I second Karol's advice, those guys know their stuff about CDI.
Old 04-05-2010 | 04:33 PM
When 2.4 came out a few years back I was and still am flying my 1/3 cub on 72 meg, I frequently had glitches, not bad ones but still they were concerning. I and some other folks attributed them to all the flying wires on the float rigging. I was told about the 2.4 eliminating any engine or metel to metal interference, so I bought a futaba 2.4 and never a glitch again. The only problem Ive ever had is when I put the ignition to close to a throttle servo on a 50cc yak and it raised hell with the servo. We used to put chokes on long servo leads back in the 80's to avoid interference, but honestly I dont even worry about it anymore
Old 04-06-2010 | 09:15 AM
MTK
ORIGINAL: Big feet
Hi Guys,
I know a lot of time has passed since I first posted this problem, other projects took over.
Last week I made some more tests on the Evolution 35cc interference problem.
Test 1 Connected power directly into the Rx and Ingition unit. No difference.
test 2 moved the batteries, IGN battery temporially cables tied to the UC, and Rx battery as far rearward as possible. No difference.
Test 3 Tried another Rx, only connecting the thro and one elevator. No difference.
test 4 Tried a different plug (resistive type). No differnece.
The engine runs Ok for a very short time, up to 10 seconds, then stops suddenly. Not ceased, it stops firing and stops rotation normally. This happens from idle or even third throttle, running smooth until the sudden stop.
After all of this my guess is a faulty IGN unit, which is also causing the interference. Any other suggestions?
If this seems a fair diagonisis, which system is the best/easist retro fit. The Evolution system is $229, silly price.
The CH system and rcExl units are much cheeper and from what I've read on here, well respected units.
Any assistance appreciated,
Cheers,
Peter
Peter,
A couple of things: first, I tried running an FM radio on 72 MHz on a gasoline powered truck that has a 26cc magneto ignition engine. I had the same sysmptoms you described...radio worked great until I started the engine, then everything would go haywire. I changed the tx and rx to 2.4 and problem was solved. Nothing generates more RF noise than an old style magneto ignition, and the proximity of components in a RC truck makes radio requirements much more demanding than in an airplane. I seriously doubt the problem is in the radio
Your specific description brought to mind a recent event in my airplane set-up, also on 2.4 Gig. The engine is a 30cc gasoline engine with RcExcl CDI unit. I was running a separate batteries for ignition and radio. The ignition battery was a 2 cell Li-ion and the radio a typical NiMH. Everything would work great as long as the engine was down. Soon as I started the engine everything would go haywire.
I traced the problem to a faulty ignition battery. Even when "fully charged", this battery was old and had developed so much internal resistance that the CDI unit would drop voltage below a usable range for the CDI (around 4 volts).
Take another look at your batteries and use fresh on the ignition.
MattK
Old 04-06-2010 | 11:34 PM
RTK's Avatar
RTK
If you are running an rcxell ignition double check by looking into the plug cap and making sure you can see the end of the resistor protruding into the open area in the top of the cap. I had one slide out which cause all kinds of glitching and engine mis.
Old 04-09-2010 | 03:26 PM
Big feet's Avatar
Thanks for all of the input guys,
I have bought an rcexl unit and will install and test tomorrow. The problem was occuring on an Evolution engine with the ignition unit that evolution supply, not the rcexl type.
MTK, I forgot to mention that I swapped out the batteries as well, just in case. No difference.
I will post back if the problem has been solved with the new unit. Fingers and toes crossed.
Cheers,
Peter
Old 04-20-2010 | 09:05 PM
  #31
The mystery of the 2.4 radio interference problem (well mine anyway) is solved! I tried a champion brand plug, and fail. I bought one of those E6 plugs from Home Depot, you know the ones that are direct replacements for many different plug types including the NGK BPMR6F plug (the one recommended for my engine). I tried this new plug and bam! MY RADIO STILL FAILED EVEN WORSE!!! I finally said to myself; dang it self, just suck it up, order the NGK BPMR6F plug from www.sparkplugs.com , pay the $10.00 shipping and try it. So I listened to myself. The plug arrived: I installed it: I tried it: And BAM! IT WORKS LIKE A CHAMP!!! Not one glitch, not one radio lock up, just one SWEEEEEEEET! running engine! Goes to prove; just use what the book calls for and you can't go wrong.
Old 04-20-2010 | 11:23 PM
  #32
Wingman26's Avatar
Surely you have one of the major auto parts chain stores somewhere near you, you can get genuine NGK plugs from one of them for about $3 and not pay shipping, they will probably have to order it and it might take a couple of days, but you still won't get stuck paying for shipping! I ordered NGK plugs from Auto Zone and had them 2 days later for around $3 or $4 each.
Old 04-21-2010 | 01:02 AM
  #33
w8ye's Avatar
My Feedback: (16)
The NGK BPMR6F has a number of "1270" when you go to order one at the counter at Advance Auto parts et al
Old 04-21-2010 | 08:17 PM
  #34
I tried to order the NGK plugs from both Auto Zone and O' Riely's. Both places said they could not get them. Ned time I need one I'll be a bit more persistent.
Old 04-21-2010 | 08:43 PM
  #35
Have you tried Advance Auto parts? I plan to tomorrow.
