Replacement for a 16x8 Prop
My Feedback: (21)
I'm thinking about putting an engine on an airframe that is using a 16x8 prop now but only has clearance for a 14 inch prop. Can I step the pitch up with a 14 incher and still have decent slow speed pull or should I go three blade? What sizes do you guys recommend?
Hi!
Of course you can, but it will not work that good!
Is it a 1.20-1.50 four-stroke?? In that case you can use a 14x10 or 14x11 (14x12 ) prop.
Extending the gear might be the best option in the long run as three blade props can be quite weighty and are sometimes difficult to find.
Karol
Karol
NM
Hey MR. Bigg. Glad to see that you finally got that SV-26 out of moth balls.
Sorry that I can't help you with a prop. I'm using the Mike Dooley recommended APC 18 x 8.
She's a turnin 7300 RPM.
Ed
Ed
NM
Karol, on the SV-26, there is no center bolt, only a smooth unthreaded shaft. Not the best arrangement in the world, but it works. Just make good and sure that the two bolts don't bottom out. Ask me how I know.
mrbigg, theAPC 18 x 8 had plenty of material, but I can't say that a smaller diameter one would.
Keep us informed.
Ed
Keep us informed.
Ed
