BME 44 info
Old 08-04-2009 | 04:29 PM
airborneSGT's Avatar
My Feedback: (15)
Default BME 44 info
Does anyone know the prop shaft size for the BME 44? Would help for prop and spinner selection.
Old 08-04-2009 | 05:52 PM
tim220225's Avatar
Default RE: BME 44 info
Boy it has been a while since I did a 440 or 50cc motor. Both were the same size and the threads were 5/16-24 IIRC.
Old 08-05-2009 | 10:33 AM
bhall01's Avatar
The threaded portion of the BME prop shaft is 8 x 1.25mm. Also, there is a 'shoulder' at the base of the prop shaft (part of the hub) that is 7/16". Your spinner backplate will need to be drilled for that, and the back of your prop will need to be 'relieved' a bit for clearance as well.
Cheers -
Barry [8D]
Old 08-05-2009 | 03:12 PM
AllTheGoodNamesAreTaken's Avatar
My Feedback: (180)
Manny,
You'll need to make some type of sleeve to use props with 10mm holes. I can show you what Brillelli did for the 46.
Jeff
