Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
Gas engine for a dynaflite super decathlon
Old 08-14-2009, 08:08 PM
runwaypete57
My Feedback: (16)
Default Gas engine for a dynaflite super decathlon
I'm looking to put a gas engine in a dynaflite super decathlon. The manufacture specs say between a 25cc and 35cc gas and all up weight between 16 & 18 lbs. Could anyone suggest what would be a good engine size? I like doing mild aerobatics. Pete
Old 08-14-2009, 10:40 PM
RCVFR
My Feedback: (7)
Default RE: Gas engine for a dynaflite super decathlon
I flew mine with a G38, 16.5 pounds, a good flyer.
Old 08-15-2009, 10:52 AM
michael wood
michael wood's Avatar
I am going to use A crrc 40cc when it arrives from china michael
Old 08-15-2009, 03:21 PM
Bass1
Bass1's Avatar
Maybe the new DL30?
Old 08-15-2009, 05:01 PM
pe reivers
An MVVS 26cc gas engine will be all you want.
Old 08-17-2009, 10:44 AM
arobatx
A G26 and G38 make pretty close to the same thrust on their best props...we've got a Decathlon in our club, 20lbs AUW with floats, and it flies great with the G26. I do like the idea of trying the DL30 once available, could be a real winner.
Old 08-17-2009, 12:29 PM
grant118
My Feedback: (26)
I used a g-38 in the one I had. It balanced out perfectly mounting the servos like on the plans and would do mild aerobatics.
chris
Old 10-01-2009, 06:21 PM
fred123
A g-38 would be an excellent choice..Fred123
Old 10-01-2009, 11:00 PM
michael wood
has anybody put a ryobi on the decathlon?
Old 10-02-2009, 05:55 PM
grant118
My Feedback: (26)
I have not but the difference between a g38 and a 31cc ryobi is night and day. My plane was about 16 lbs and the g38 balanced it out good. I used a 20" apc prop also. I would think a ryobi would be too small and you would need a long runway for take off and not be able to do aerobatics very well. It was not overpowered with a G38 and would do scale areobatics, ie no hovering. Hope this helps.
chris
Old 10-02-2009, 06:26 PM
michael wood
well I just got my crrc 40 up and running with a new ignition module so I guess I will use that michael
