spe 43 cc
NH
spe 43 cc
have one of these. after hours of researching threads. printing out a degree wheel and correcting the timing. was about 55 degrees btdc, corrected to between 28 and 30 btdc. melody ign sparks on a slow turn when timing just as magnet comes under hall sensor. read somewhere it should spark as magnet leaves sensos. which is right? need to adjust needles. printed directions from t. o m. seems simple enough. running 32 to 1 now. less than a gallon on a 19x10. oil is tech something aircooled from wally world. flying a yak 25% from peak models. using homemade 4.8 volt aa batteries nimh from wally wolrd for ign. and 4000 mah 4.8 nimh from radio shack or wally world for reiever, mounted behind c.g.for balance purposes. does this seem enough? want to mount a smoke system in canopy on cg usising seperate battery. dooes this seem ok?
thanks
al
thanks
al
