Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 G-45 and G-62 same exhaust pattern?? >
Old 08-28-2009 | 12:15 PM
flygilmore's Avatar
Default G-45 and G-62 same exhaust pattern??
Despite searching everywhere, including the Zenoah manual, I cannot find a def. answer on this. Do the G-45 and G-62 share the exact same exhaust pattern?? The manual shows them using the same #muffler gasket so I would assume but wanted to make sure. Reason is I have found a good deal on a header for a G-45 and if it fits, I need it for a G-62.
Thanks!
Old 08-28-2009 | 12:22 PM
w8ye's Avatar
My Feedback: (16)
Default RE: G-45 and G-62 same exhaust pattern??
They are pretty much the same engine except for the bore and stroke
Old 08-28-2009 | 12:26 PM
flygilmore's Avatar
Yes....but that doesn't answer my question specifically.
Old 08-28-2009 | 12:49 PM
My Feedback: (33)
The bolt pattern maybe the same but the G-45 muffler is mounted on an angle and for that reason it has an angled shaped spacer on the muffler. The G-62mdoes nopt have the angled spacer. Stuka Jon
Old 08-28-2009 | 08:02 PM
Only difference in these engines is the jug bore and stroke......muffler, magneto, carb, even the prop nuts are the same..
Old 08-28-2009 | 09:01 PM
tkg
The bolt pattern is the same, BUT using a G-62 muffler of any shape on a G-45 makes for a cockeyed muffler. Especially with a Pitts style.
