Diameter of inlet and exhaust of canister muffler
My Feedback: (35)
WA
Can you guys tell me what is the approx diameter of the inlet and exhaust pipe for a Canister muffler used for a 50 cc engine ?
Also what kind of coupling material is used between muffler and header?
RE: Diameter of inlet and exhaust of canister muffler
The inlet and outlet can vary by manufacturer and pipe design. For the coupler, go to an area truck and tractor supply and obtain some high temp heater hose. MUCH cheaper than the stuff sold by the pipe people and holds up about 25 times longer.
Where are you at in Vancouver and where do you fly? I'm in the same town for awhile and fly over at Washougle.
My Feedback: (35)
WA
I fly at Washougal also . However weather this week is definitely bad for flying East Winds are predominant at this time of the year so landings have to down wind due to club rules of landing from left to right .
Typical diameter for 50cc engines would be 25mm pipe OD on header pipe and canister inlet pipe. (mtw TD75, MVVS 58int, JMB etc.)
My Feedback: (35)
WA
PE, tks for the info re typical inlet and exhaust pipe dia
Tired Old Man, I fly the GP SU31 and various other planes. See you at the field sometime when the weather breaks!
