mounting a gas engine vs glow engine
sorry for the dumb question, but what, if any differnce is there in mounting a gas engine. I use tri-stock, fiberglass, and fuel proof the firewall, is there any thing else that should be done or looked at? thinking about putting a dle30 on a GP PT17 stearman
Nothing any different really. The fasteners are larger, and you typically do not have to buy a separate engine mount. Stand offs can be easily and economically made at home out of wood dowel. Most of the ARF airframes are plenty strong enough to handle the appropriate sized gas engine if the kit was originally intended for a gasser. The Stearman should be able to handle the mounting of a 30, no problem.
The question would only have been dumb had it not been asked.
FL
Here is great article... penned by T.O.M... on making your own custom standoffs using dowels. It is the perfect How-to
[link=http://www.rcaer.com/pages/files/Aerovate - Engine Mounting with Wood Dowels.pdf]Engine Mounting with Wood Standoffs[/link]
Cheers
Henry
Cheers
Henry
ORIGINAL: Piston
Cheers
Henry
Cheers
Henry
I know you only asked about mounting the engine but are you aware that gas requires a different fuel tubing and rubber tank stopper than nitro? There is no "pressure" tap on the exhaust but the carbs are pumped so it is not needed. You still need to vent the gas tank so it does not create a vacume in the tank.
yea, thanks, been doing research, read the sticky and it is a little vague on mounting to me, but have seen so many different ways that I was getting confused, and like Kentucky Colonel, think i like the wood dowel method link posted by Piston
MI
Remember when you set up the fuel tank to loop the vent line all the way to the back of tank so gas doesn't siphon out when you point the plane down, flying or not flying. Sorry but i don't have a pic to explain this.
